If your hoverboard is experiencing issues where it will not move forward or unable to maintain balance, there is a problem with the gyroscope controlling the wheels.
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove the bottom cover by lifting it away from the hoverboard.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
Place the hoverboard so the sensor boards face you.
Remove battery connector by pulling it apart.
Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
Disconnect the colored wires by pulling them apart.
Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
Remove the four 10mm screws with a Phillips #1 screwdriver.
Remove the sensor board by lifting it away from the hoverboard.
crwdns2947412:09crwdne2947412:0
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do you get replacement board?
Tim Sole - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do you get circuit board from.
markrichardowen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
