Does your Hover-1 Horizon not turn off? This is a guide to show you how to replace the power button, the most likely cause of your issue. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
Remove the six 12mm Phillips #2 screws holding the base plate.
Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
Remove the base plate by lifting it up.
Reorient the Hover-1 Horizon so the base plate opens towards you.
Remove the connector by squeezing the tab and lifting up.
Remove the second connector by squeezing the tab and pulling up.
Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
Push the power button through the base plate to remove.
