Hover-1 Horizon Left Balancing Sensor Replacement
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 12mm Phillips #2 screws holding the base plate.
    2. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    3. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two connectors on either side of the board by lifting the tab and pulling out.
      • Remove the connector in the middle of the board by squeezing the tab and pulling up.
    2. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 11mm Phillips #1 screws that hold the cover on.
    3. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
      • Lift the board to reveal the connections on the bottom.
    4. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the middle connector by squeezing the top of the tab and pulling up.
    5. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
      • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    6. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unclip the black connector by squeezing both sides and pulling them apart.
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
      • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
    2. Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Horizon Left Balancing Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the sensor tab by carefully lifting it away from the hoverboard.
Jesus
crwdns2935283:010/08/18crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S13-G6, White Fall 2018 crwdns2935289:0Cal Poly, Team S13-G6, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S13G6
crwdns2942667:0crwdne2942667:0 1,618
