Hover-1 H1 Charging Port Replacement
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 H1 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 H1 Charging Port Replacement, Charging Port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 H1 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 H1 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the charging port to the left through the shell.
Madeline David
crwdns2935283:010/08/18crwdne2935283:0
286 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G6, White Fall 2018 crwdns2935289:0Cal Poly, Team S17-G6, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S17G6
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - crwdns2934203:0crwdne2934203:0
Who can I contact to fix this charging port on this H one hover one hover board
Hover1 h1 hoverboard - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 4,513
