Hover-1 Folding E-Scooter Rear Wheel Replacement
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide off the plastic side panel.
    What is the Pat number of this plastic side panel?
    bobdub - crwdns2934203:0crwdne2934203:0
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Luke Imai
crwdns2935283:010/08/18crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G5, White Fall 2018 crwdns2935289:0Cal Poly, Team S15-G5, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S15G5
Where can you get replacement rubber for the front and rear wheels?
jackricotta - crwdns2934203:0crwdne2934203:0
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 5,690
