Is your deck on your Hover-1 Folding eScooter damaged? If so here is a guide to help you replace it with a new one.
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
Slide off the other plastic side panel.
On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Hold the two 10mm nuts in place with a 10mm wrench.
Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise.
Fold the scooter by releasing the latch and pushing the handlebars to the rear of the device.
Hold the two hex nuts in place with a 10mm wrench.
Remove the next two 33 mm bolts attached to the 10 mm hex nuts by turning a hex 4.0 screwdriver counterclockwise.
To reassemble your device, follow these instructions in reverse order and use the new deck instead.
The latch does not operate properly and is missing a part on the right side so it cannot retract the steel bar that locks the position. What part do I need and can you pls send it? It’s a brand new unit.
Original NYC ScooterCommuter - crwdns2934203:0crwdne2934203:0
step 7 is where mine is broken .. it was kicked hard and right after the 2 screws but before the curb has been snapped what do i do
