This guide is designed to help you replace a broken or damaged brake switch. All you will need is a #0 and #2 Phillips screwdriver to remove the screws in this guide
Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
Remove the red brake switch by sliding it off the main body.
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Hi, I’m looking for a Hover-1 Eagle left handle? Do you where can I find it? Thanks
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Looking new break switch.where we will get?. please reply.
Looking for a throttle switch. Know where I can find one?
