Hover-1 Eagle Back Wheel Replacement
  1. Hover-1 Eagle Back Wheel Replacement, Back Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the reflective red axle sticker using a plastic spudger.
  2. Hover-1 Eagle Back Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 2mm screw located underneath the reflective sticker.
  3. Hover-1 Eagle Back Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Eagle Back Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Eagle Back Wheel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the deck flare and slide it towards the tail end of the scooter.
  4. Hover-1 Eagle Back Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 mm axle screws by using a hex bit 5.0.
    • Make sure to try loosening both sides. One of the axle screws spins freely and will not loosen.
  5. Hover-1 Eagle Back Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Eagle Back Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Eagle Back Wheel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat Steps 1-3 for the other side.
    • Apply pressure to the axle using a hex bit 5.0 to push it slightly out on the other side.
    • Take hold of the 6 mm axle screw on the opposite side and remove the axle by pulling firmly towards you.
  6. Hover-1 Eagle Back Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Eagle Back Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull backwards to remove the back wheel.
    • Washers may fall when the wheel is removed, so make sure to catch or gather the washers.
To reassemble your device, repeat Steps 1-4 in reverse order.
Andrew Gaskell
crwdns2935283:001/23/20crwdne2935283:0
1 062 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G2, White Winter 2020 crwdns2935289:0Cal Poly, Team S1-G2, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S1G2
Where do you buy the wheels
Thanks
antonio flores - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 2,835
