Hover-1 Charger Outer Shell Replacement
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Outer Shell Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left foot pad from the hoverboard.
Mark Rapiz
crwdns2935283:010/10/19crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G1, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G1, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G1
Where do I buy the shell their website doesnt have it
firestineanthony - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 595
