Hover-1 Charger Gyroscope Sensor Board Replacement
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gyroscope sensor board.
Melanie Hardell
crwdns2935283:010/10/19crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G1, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G1, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G1
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - crwdns2934203:0crwdne2934203:0
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - crwdns2934203:0crwdne2934203:0
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - crwdns2934203:0crwdne2934203:0
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 5,407
