Hover-1 Charger Gyroscope Sensor Board Replacement
Melanie Hardell
crwdns2944109:0crwdnd2944109:0Melanie Hardellcrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0N'w 23, 2019crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If you are having trouble balancing on your Hover-1 Charger (H1-COL), there may be an issue with its gyroscope sensor boards. Before you begin disassembling your hoverboard, check out our troubleshooting page addressing hoverboard balancing. If the problem persists, this guide will help you replace your hoverboard’s right gyroscope sensor board. Removal of the left gyroscope sensor board will follow very similar steps.
Make sure to wear an anti-static wrist strap to protect the electronics against buildup of static electricity. Some screw housings are fragile; they may fall apart when the screw is removed.
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
    Where can I buy a gyro balancer for this hoverboard
    Matthew - crwdns2934203:0crwdne2934203:0
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
    What are these gyroscopes model number hard to find for X hover - 1. I need some
    Simon Bull - crwdns2934203:0crwdne2934203:0
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gyroscope sensor board.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Melanie Hardell
crwdns2935283:010/10/19crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G1, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G1, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G1
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - crwdns2934203:0crwdne2934203:0
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - crwdns2934203:0crwdne2934203:0
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - crwdns2934203:0crwdne2934203:0
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 5,456
