Hover 1 Eclipse Shell Replacement
    1. Hover 1 Eclipse Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
      • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
      • Remove the plug side bottom shell piece.
      • Be cautious of the wires connecting the plug side shell piece to the body. Do not pull the piece off until these wires have been disconnected in the following step.
      • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the remaining bottom shell piece.
      • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the remaining side bottom shell piece.
      • Remove final bottom shell piece
    2. Hover 1 Eclipse Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • On the bottom plug side shell pieces, there are two white and pink wires connecting the shell and the motherboard.
      • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
      • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
      • Now you can fully remove the bottom plug side shell piece.
    3. Hover 1 Eclipse Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the yellow tipped plug attached to the red and black cord on the non-battery side.
    4. Hover 1 Eclipse Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips #1 Screwdriver, remove the twelve 11mm and 13mm screws that line the bottom inside of the battery side of the Hover-1 Eclipse.
      • The screw placement is mirrored on the other side
      • Repeat these steps for the left inside of the Hover-1 Eclipse.
    5. Hover 1 Eclipse Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hover 1 Eclipse Shell Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push down the shell and LED light near the center of the board as shown.
      • In the newly exposed area, there will be an 11mm screw holding in the wire that connects to the LED light of the frame. Remove this screw.
      • Now separate the light from the shell and board.
      • Repeat this for the other 3 lights.
    6. Hover 1 Eclipse Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hover 1 Eclipse Shell Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Follow the rainbow cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
      • The cord is a bundle of multicolored wires sheathed in black, halfway down.
      • Follow the black and blue cord that connects the left side shell piece to the inside board. Find where it is plugged into and disconnect it.
      • Repeat for the top right shell piece.
      • Remove both shell pieces.
Stone Burgan
crwdns2935283:010/10/19crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G4, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S12-G4, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S12G4
Where can I buy the shell please help me
luke - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 1,570
