Hot Tools Professional 1110 Disassembly
  1. Hot Tools Professional 1110 Disassembly, Hot Tools Professional 1110 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
    • In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
  2. Hot Tools Professional 1110 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hot Tools Professional 1110 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
    • With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
    • Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
  3. Hot Tools Professional 1110 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the ring loose, turn the handle body over, and you will see three screw holes.
    • Take a PH1 screwdriver, and loosen up all three 6mm Phillips #1 screws in the handle body.
  4. Hot Tools Professional 1110 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws have been removed, set them aside and with a pry tool, firmly pull the handle body apart in half lengthwise.
  5. Hot Tools Professional 1110 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hot Tools Professional 1110 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For removing the clamping mechanism, firmly grasp the iron in your hand by the handle body, and locate the screw as shown in the picture.
    • Remove the screw shown (8mm Phillips #2 Pan Head) and when finished do the same for the opposite side.
  6. Hot Tools Professional 1110 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once both screws have been removed, continue to remove the top clamping half of the mechanism from the body of the Iron.
  7. Hot Tools Professional 1110 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the handle, and remove the screw that holds on the spring mechanism for the clamp. This screw is a 8mm Phillips #2 Pan Head.
    • Once this step is fished your Hot Tools Professional 1110 will be fully disassembled and ready to have its components replaced.
Sean Neal
crwdns2935283:011/11/17crwdne2935283:0
IUPUI, Team S2-G2, Wilson Fall 2017 crwdns2935289:0IUPUI, Team S2-G2, Wilson Fall 2017crwdne2935289:0
IUPUI-WILSON-F17S2G2
where can i get or order the part for the (spring with small roller)
i have a model ht1110xl hot tools iron
Fred Medina - crwdns2934203:0crwdne2934203:0
What is the c/b that acts as the on/off switch? It was improperly shrink wrapped causing it to burn through and break the switch
Kim P. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 4,551
