Hot Tools HPK12 Prerequisite Only
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Hot Tools HPK12 Prerequisite Only, Prerequisite Only: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Prerequisite Only: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Prerequisite Only: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hot Tools HPK12 Prerequisite Only: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Prerequisite Only: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Prerequisite Only: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Prerequisite Only: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Hot Tools HPK12 Prerequisite Only: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
Aaron Whitlock
crwdns2935283:010/24/16crwdne2935283:0
249 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-4, Baechle Fall 2016 crwdns2935289:0IUPUI, Team 3-4, Baechle Fall 2016crwdne2935289:0
IUPUI-BAECHLE-F16S3G4
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 134
