Damaged belt may be the reason for the vacuum not picking up debris properly. This guide will show you how to open the bottom plate of the machine and replace the belt underneath.
Remove the 4 phillips 3/4'' screws.
Separate the belt from the brush roll.
crwdns2935219:0crwdne2935219:0
To reassemble your device, follow these steps in reverse order.
That isn’t the steering belt. That is the agitator belt.
