This guide is for the Hoover Rogue 970 (Model BH70970) Smart Vacuum.
Are your Hoover Rouge 970 wall brushes not able to move, preventing the vacuum from cleaning? If so, here is a guide to fix the problem with a simple change of the wall brushes.
If this simple replacement doesn't fix your issue, visit our Wall Brush Motor Replacement Guide!
Flip the vacuum over so the wall brushes are facing up.
Remove the two 8.2 mm screws using a Phillips #2 screwdriver.
Gently lift up on the wall brushes to remove them from the vacuum.
