Nozzle that releases the water/solution and sucks up dirty water. Also where the hose can be attached/detached. This nozzle may need to be cleaned after usage, so removal is necessary.
Unlatch the grey switch labeled “Tank Release”.
Gently pull on the water tank until it releases from the base.
Lift the switch that was covered by removing the tank.
