crwdns2959928:0crwdne2959928:0 ↓The suction motor is at the core of the proper function of any household floor cleaner. This guide will demonstrate how to properly replace a broken suction motor.
Lay the cleaner down horizontally with its wheels closest to the floor.
Hold the lower brush roll with both hands and pull outwards until it is detached.
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Pull the red handle shown to remove the front suction unit from the cleaner.
Unscrew the Phillips #2 screw at the bottom of the hose.
Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
Repeat the above step for the "On/Off" button.
Gently grab the belt and pry it off from the rollers.
Unscrew two screws using Phillips #2 screwdriver.
Detach grey piece from vacuum.
Unscrew four screws using a Phillips 2 screwdriver.
Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
Unscrew two screws with Phillips #2 screwdriver.
Detach motor and unscrew two screws with a Phillips #2 screwdriver.
Pull the bottom section off.
Pull the cap off.
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
