Hoover Power Path Pro Advanced Power Switch Replacement
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Power Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the red power the red power switch.
Jose Andres Gonzalez Valdes
crwdns2935283:001/22/18crwdne2935283:0
682 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G5, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S16-G5, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S16G5
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 4,253
