This guide will show you how to replace the wheels of your device. This would be needed if your device fails to roll on the flooring or if they simply broke apart. Be sure to remove the battery from the device and switch the power off.
Detach the rolling assembly from the body by pushing the button found at the base.
Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
Remove the brush and retainer from the rolling assembly.
Remove the eight 4mm Phillips #1 screws from the bottom panel.
Remove the black plastic clamp from inside the wheel axle.
where can i buy these rubber wheels ? They worn out fast.
