This guide will show you how to replace the internal switch inside the handle. This guide will be identical to the motherboard guide with a few extra steps. This would be needed if the power button is no longer working in the handle.
Remove the single 15mm Phillips #1 screw from the handle.
Remove two 15mm Phillips #1 screws from the handle.
Use a plastic opening tool to carefully pry the black cover off of the handle.
Remove five 15mm Phillips #1 black screws from the handle.
Remove the silver plastic cover using the plastic opening tool.
Remove the black rubber cover from the motherboard.
Remove two 8mm Phillips #1 screws from the motherboard.
Carefully pull the motherboard out with its attached wires.
Replace the power button.
