Honeywell Turboforce Motor Replacement
  1. Honeywell Turboforce Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
    • The screw channel is long and it is recommended to use a screwdriver with a long shaft or a screwdriver with a skinnier handle.
  2. Honeywell Turboforce Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry apart the blade cover from the body of the fan to access the inside.
  3. Honeywell Turboforce Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 36mm screws on the metal plate behind the blades using the Phillips #1 screwdriver.
  4. Honeywell Turboforce Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the motor forward out of its resting position and tilt it forward revealing the back of the motor.
    • Beware of the wires attached to the back of the motor.
  5. Honeywell Turboforce Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the two 37mm screws on the back of the motor.
    • Beware that there is a nut holding the screw in place on the opposite side of the motor.
    • Beware once the screw is removed the metal brace where the screws are located will come off.
  6. Honeywell Turboforce Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the circular motor from the square holder.
    • The fan blades will still be connected to the circular motor.
  7. Honeywell Turboforce Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell Turboforce Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the felt washer, metal washer, and the rubber stopper from the axle.
  8. Honeywell Turboforce Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor and replace it with the new part.
    • Consider using a lubricant to insert the new motor.
crwdns2935229:011crwdne2935229:0
Jake Hallem
crwdns2935283:009/18/19crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S4-G6, Ives Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S4-G6, Ives Fall 2019crwdne2935289:0
ERAU-IVES-F19S4G6
What is the motor parts details to procure elsewhere?
patra gyanesh - crwdns2934203:0crwdne2934203:0
Hi informative guide but first how do we get the new motor how do you remove the blade nut to remove the blade from the old motor shaft
Dave Gordon - crwdns2934203:0crwdne2934203:0
Given the difficulty of finding a replacement motor with three speeds and the correct mounting configuration, it makes more sense to buy a new model of this fan. Much faster, too.
Sprockets John
John Sprockets - crwdns2934203:0crwdne2934203:0
Top notch how to document! Commentary and photos are excellent. Good job! And thank you very much
M Robarton - crwdns2934203:0crwdne2934203:0
Where are y’all finding the motor? Please advise… this looks doable! Thank you for your assistance. Michelle
Michelle Paredes - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 90
crwdns2942667:0crwdne2942667:0 9,813
