Honeywell Quietset HY5260BC Fan Blades Replacement
  1. Honeywell Quietset HY5260BC Fan Blades Replacement, Fan Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To avoid risk of electrocution, unplug the fan from the power outlet.
    • Lay the fan horizontally and remove the base by unscrewing the locking nut from the fan housing.
  2. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3” wing screw on the bottom of the fan; then, remove the four 3" screws on the top of the fan.
    • A Torx screwdriver is required for this process.
  3. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully open up the fan housing in half by pulling the front and back parts away from each other. You should now be able to see the motor attached with the fan blade.
    • This may require a large amount of force, so proceed with caution. You may use a plastic tool to separate the parts.
  4. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw connecting the motor shaft with the bottom half of the fan blade.
  5. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws connecting the metal bracket with the fan blade and remove the metal bracket.
  6. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To carefully remove the fan blades, grab the fan blades firmly and lift them toward yourself.
    • Gently clean the inner surface of the fan with a cloth or a vacuum cleaner to remove all the dust that has collected through usage.
  7. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To fix the rattling noise, carefully apply lubricating grease around the blade drum’s shaft.
    • Make sure not to drop any of the lubricants onto the bearing!
  8. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lubricate the metal bracket’s tab and around the screw holes.
    • To avoid a future squeaky noise, put a liquid rubber on the top surface during reassembly. This effectively prevents friction.
  9. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly place the new fan blades in correct alignment.
    • The slots on the fan blades and centre column must be aligned perfectly.
  10. Honeywell Quietset HY5260BC Fan Blades Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To stop the new fan blades from vibrating, tighten the screws around the metal bracket and motor shaft. Then, place the other half of the tower casing and screw it in place.
    • It is important to connect and adjust all parts of the tower fan securely in place to avoid noise.
To reassemble your device, follow these instructions in reverse order. Follow this guide to self-service your tower fan yourself saving lots of money!
fabiha tarannum
crwdns2935283:001/21/21crwdne2935283:0
202 crwdns2915208:0crwdne2915208:0
York University, Team S1-G31, Melo-Thaiss Winter 2021 crwdns2935289:0York University, Team S1-G31, Melo-Thaiss Winter 2021crwdne2935289:0
YORK-MELO-THAISS-W21S1G31
Where can I buy the fan blades
Dan Man - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 5,215
