This guide shows a step-by-step process for removing a broken, old, or non-functional main board for a Honeywell Quietset Tower Fan HYF260BV2 and replacing it with a new one.
Safety Tips:
- Unplug your fan before doing anything.
- Wear a mask if your fan is very dusty.
Unplug your fan and place it on its side.
Twist the red plastic piece off from the bottom.
Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
Pull off the back of the fan and set it aside.
Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
Remove the two larger 14 mm Phillips #1 screws located below.
Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
Pull the gray cover from the fan to reveal the main board.
Carefully hold the edges of the main board and slowly pull it out.
Unplug the main board.
Follow the cables connected to the board to the bottom of the fan.
Unplug the connector to disconnect the bundle of wires.
Use scissors to cut the zip tie that secures the wires.
Pull the wires up and slide them out of the fan to replace the main board with a new one.
