Honeywell HYF260BV2 Main Board Replacement
  1. Honeywell HYF260BV2 Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement, Main Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your fan and place it on its side.
    • Twist the red plastic piece off from the bottom.
    • Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
  2. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
  3. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
  4. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
    • Do this gently because you could break the connectors for the back of the fan.
  5. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the back of the fan and set it aside.
    • Dust the inside of the fan if it is needed.
    • Be careful when dusting and ensure nothing is knocked out of place.
  6. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
    • Remove the two larger 14 mm Phillips #1 screws located below.
    • Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
  7. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the gray cover from the fan to reveal the main board.
  8. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully hold the edges of the main board and slowly pull it out.
  9. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the main board.
    • Follow the cables connected to the board to the bottom of the fan.
  10. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the connector to disconnect the bundle of wires.
    • Use scissors to cut the zip tie that secures the wires.
    • Be careful when you cut the zip tie so that you don't accidentally cut the wires.
  11. Honeywell HYF260BV2 Main Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wires up and slide them out of the fan to replace the main board with a new one.
Joshua Moreno
crwdns2935283:010/16/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 28-7, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 28-7, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S28G7
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 209
