Honeywell HY-204 Control Panel Replacement
  1. Honeywell HY-204 Control Panel Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HY-204 Control Panel Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HY-204 Control Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HY-204 Control Panel Replacement, Control Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Nolan Ernotte
crwdns2935283:010/14/14crwdne2935283:0
384 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-40, Amido Fall 2014 crwdns2935289:0Cal Poly, Team 10-40, Amido Fall 2014crwdne2935289:0
CPSU-AMIDO-F14S10G40
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 614
