This guide is necessary to complete before many of our other replacement guides, but it can also stand alone as a replacement guide for the control panel. This is a really simple guide and should only take you a few minutes!
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
