Honeywell HT900C Motor Replacement
  1. Honeywell HT900C Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
    • Due to the small size of the screw holes, a long and thin screwdriver may be necessary.
  2. Honeywell HT900C Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To gain access to the fan's inner workings, gently pull the blade cover away from the main body.
  3. Honeywell HT900C Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 36 mm screws from the metal plate located behind the blades using a Phillips #1 screwdriver.
    • The screws can be hard to remove so you may need to twist the screwdriver harder and screws can be removed easily.
  4. Honeywell HT900C Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the motor it out of its resting position and tilt it forward to access the back of the motor.
  5. Honeywell HT900C Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 10 mm screws from the motor's back using a Phillips #1 screwdriver.
  6. Honeywell HT900C Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 20 mm screws beside the fan blade using a Phillips #1 screwdriver.
    • The screws are attached to two parts of the motor so it can easily fall off after removing the screws.
  7. Honeywell HT900C Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the circular motor from the square holder.
    • The circular motor is still connected to the fan blades.
  8. Honeywell HT900C Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honeywell HT900C Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal washer from the axle.
  9. Honeywell HT900C Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the old motor with a new one, and you're done!
    • Using the lubricant to easily put the new motor back.
    • Always double-check that the screws are securely in place.
Duy Anh Nguyen
crwdns2935283:009/17/22crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
York University, Team B-10, Allen Fall 2022 crwdns2935289:0York University, Team B-10, Allen Fall 2022crwdne2935289:0
YORK-ALLEN-F22SBG10
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 1,065
