Some soldering will be required in order to complete the speaker replacement.
Flip your amp over to begin removing the plastic cover.
Remove the battery cover and take the battery out.
Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
Remove the back cover by carefully pushing the battery connector through the hole in the cover.
With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
Use flush wire cutters to remove black and red wires from the old speaker.
Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
Connect the battery and turn the power on to test proper connection of the new speaker.
Reverse steps 1-5 to complete repair.
Connect the amp to your favorite instrument and test out the new sound!
crwdns2917034:0crwdne2917034:0
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
