Honda S2000 VTEC Solenoid Upper Replacement
  1. Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement, VTEC Solenoid Upper: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the VTEC solenoid on the front left of the engine.
  2. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and remove the 3 bolts. Set them aside.
    • Do not drop the cable that is attached by a bolt.
  3. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the plug upwards and off of metal cable holder. Disconnect the two cables.
  4. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the metal cable holder and set it to the side.
    • Pull off the upper VTEC solenoid.
  5. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a new replacement upper solenoid.
    • Place the gasket (new or used if still good) into its slot.
    • A gasket is a flexible material that is used to make a seal between two connections. This prevents leaks between the two surfaces.
    • Spread a small amount of oil along the gasket.
  6. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the replacement upper solenoid back onto the solenoid.
  7. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a metal cable holder and place one of the bolts into it.
    • Hand tighten all three bolts.
    • Ensure the metal cable holder is straight.
  8. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tighten all 3 bolts with a ratchet carefully. Do not overtighten as you can strip the bolts.
    • Plug the cable back in, and attach it to the metal holder.
  9. Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda S2000 VTEC Solenoid Upper Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wipe down the edges where the two parts meet to pick up any oil that may have spilled.
    • Keep an eye on the solenoid for any oil leaking after cleaning.
Congratulations! You now have a properly working VTEC solenoid. Be sure to keep an eye on the solenoid in case of any oil leaks.
Angeljauregui
crwdns2935283:003/12/24crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 1-17, Harris Spring 2024 crwdns2935289:0CSU Los Angeles, Team 1-17, Harris Spring 2024crwdne2935289:0
CSULA-HARRIS-S24S1G17
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 739
