Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Turn off the fuel valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Remove outer belt cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the bolt securing the outer belt cover.
  4. Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
  5. Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Transmission Pulley Bolt Release, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step may require two people.
    • Pull the tine engagement lever to put belt tension on the transmission pulley.
    • With the belt taut, use a 12 mm socket to loosen the transmission pulley bolt without fully removing it.
    • The pulley will rotate with the bolt and the bolt will not be able to be removed if belt tension is not applied.
Carsten Frauenheim
146,626 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,175crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 17
