This guide shows how to remove and replace the rotary tine oil seals on a Honda FRC800K1A Rear Tine Tiller.
Drain the oil from the transmission before beginning this process.
After completing this procedure, refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Flip the fuel valve switch to the off position.
Use a 12 mm socket and wrench to remove the six sets of side guard bolts and nuts, three on each side.
Slide the side guard off of the curved main guard to remove.
Use a 14 mm socket to remove the two rotary tine retaining bolts.
Slide the rotary tine off its axle to remove it.
Wedge a large flathead screwdriver underneath the metal lip on the oil seal.
Firmly pry the seal away from the transmission.
With enough room to grab the oil seal, pull it out of its housing.
Remove the oil seal.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
