Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement
  1. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Turn off the fuel valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove outer belt cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the bolt securing the outer belt cover.
  4. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
  5. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step may require two people.
    • Pull the tine engagement lever to put belt tension on the transmission pulley.
    • With the belt taut, use a 12 mm socket to loosen the transmission pulley bolt without fully removing it.
    • The pulley will rotate with the bolt and the bolt will not be able to be removed if belt tension is not applied.
  6. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the V-belt towards the transmission pulley to release tension.
    • Slip the V-belt off of the groove in the pulley.
  7. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the V-belt down and out of the way of the two-prong belt guide.
    • Push the V-belt around and off of the motor pulley to remove.
  8. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the belt guides: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the two bolts securing the belt guides to the inner belt cover.
    • Use a 10 mm socket to remove the bolt securing the inner belt cover to the frame.
  9. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Lower the guard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Lower the guard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to loosen the two bolts securing the guard to the frame.
    • These bolts have corresponding 14 mm nuts on their opposite ends. You will need to keep the bolts steady with a wrench or socket for the nuts to become loose.
    • Remove both nuts, but do not remove the bolts yet.
  10. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the frontmost guard bolt.
  11. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the guard and lower it to the ground, pivoting it on the rear guard bolt.
  12. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the pulley bolts: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the motor and transmission pulley bolts.
    • Hold the pulleys steady to more easily remove the bolts.
  13. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the motor pulley: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the motor pulley: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor pulley.
    • Keep track of the key—which may fall out on its own—and keep it with the motor pulley.
  14. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the transmission pulley straight off of the splined shaft to remove.
  15. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use snap ring pliers to remove the snap ring securing the tensioner pulley to its shaft.
  16. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tensioner pulley.
  17. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to remove the three wire clips securing various cables to the back of the inner belt cover.
  18. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the two remaining inner belt cover bolts behind the transmission pulley.
  19. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the inner belt cover clear of the motor and transmission shafts.
    • Remove the inner belt cover.
  20. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the side tine guards: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the side tine guards: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 12 mm socket and wrench to remove the six sets of side guard bolts and nuts, three on each side.
  21. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the side guard off of the curved main guard to remove.
    • Repeat the same process on the opposite side.
  22. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the rotary tine: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the two rotary tine retaining bolts.
    • Repeat the same process on the opposite rotary tine.
  23. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rotary tine off its axle to remove it.
  24. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the drag bar: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the drag bar: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the drag bar: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 14 mm socket to remove the bolt holding the drag bar in place.
    • Remove the drag bar.
  25. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the cable guide: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the cable guide screw.
  26. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cable guide's metal clip out of the shifter frame.
    • Unwind the cables from the cable guide.
    • Remove the cable guide.
  27. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the cable clips: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  28. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the tensioner spring: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the tensioner spring: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the tensioner pulley arm to loosen the tension on the tensioner spring.
  29. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top of the tensioner spring from the end of the clutch cable.
  30. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom side of the tensioner spring from the tensioner arm.
    • Remove the tensioner spring.
  31. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the clutch cable: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the clutch cable: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the clutch cable: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the clutch cable to remove it from its slot.
  32. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable from the cable guide.
  33. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  34. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove change lever extension: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove change lever extension: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove change lever extension: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to straighten the change lever pin.
    • Pull the pin straight out to remove.
  35. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the change lever extension off its base to remove.
  36. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift linkage mounting bracket: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three shift linkage mounting bracket bolts and nuts:
    • Two 12 mm bolts and nuts
    • One 14 mm nut
    • This nut is holding the tensioner pulley arm assembly to the bracket. It may fall away once you remove this nut.
  37. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the shift linkage mounting bracket away from the frame.
    • If it hasn't already come off, the tensioner pulley arm assembly may fall away once you remove the mounting bracket.
  38. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pivot the shift lever out and away from the shift gate to remove it.
  39. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift gate: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the two shift gate through-bolts.
  40. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the shift gate off of the transmission to remove it.
  41. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shifting arms: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shifting arms: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shifting arms: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the rotary change shifting arm bolt.
    • Remove the rotary change shifting arm.
  42. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the two remaining shifting arm bolts.
    • Remove the two remaining shifting arms.
  43. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the handle: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the front handle bolt.
    • Use a 14 mm socket to remove the shouldered handle angle selection bolt.
  44. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and rotate the handle off of the frame towards the motor.
    • Be careful not to snag, bend, or rip any cables as they are all still attached to the handle.
    • Set the handle near the motor.
  45. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the blade guard: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 17 mm socket to remove the three frontside blade guard bolts.
    • Use a 14 mm socket to remove the four backside blade guard bolts.
  46. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the blade guard up and off of the transmission to remove it.
  47. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Separate the transmission from the frame: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motor may fall away from the transmission during this step if it is not properly supported. Take care to ensure both the transmission and motor are supported.
    • Use a 14 mm socket to remove the two frame bolts.
  48. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The transmission and motor are both very heavy. This may require two people.
    • Consider supporting the transmission with jack stands so you can easily remove the wheels in the coming steps.
    • While supporting both sides, roll the transmission away from the motor and frame.
  49. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wheels: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wheels: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the wheels: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wheels.
    • Make sure the transmission is supported such that there isn't too much pressure on the now-exposed axles.
  50. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Support the transmission: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Support the transmission with jack stands so the seam between the two halves is level with the work surface.
    • Orient the transmission such that the right half of the case is facing up. This is the side containing the shift holder assembly.
  51. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Separate the two halves of the case: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirty-two transmission case fasteners:
    • Thirty 12 mm bolts and nuts
    • Two 14 mm bolts and nuts
    • Reinstallation tip: Install five to eight 12 mm transmission case bolts equidistant around the circumference of the two halves of the case to tighten the two halves together. Once the two halves are mated, reinstall the rest of the 12 mm and the two 14 mm transmission case bolts in a criss-cross pattern.
    • Torque all transmission case bolts to 16 ft-lb (22 Nm). Re-torque all transmission case bolts after five hours. Wipe off any excess liquid gasket that squeezes out after you start tightening the two halves together.
  52. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the three bolts securing the shift holder to the right transmission case.
  53. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a sharp blade to cut away any gasket material around the shift holder assembly.
    • Always cut away from yourself and others.
  54. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a large flathead screwdriver in between the two halves of the transmission case to pry them apart and break the gasket seal.
    • This may require a lot of force.
  55. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the flathead screwdriver around the transmission to create a small gap along the entire perimeter of the case.
  56. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the top case is removed, the transmission gearing becomes exposed and has a tendency to move around. If gears, bearings, or washers fall out of their positioning, you will need to consult official Honda schematics to ensure proper reinstallation.
    • Use a mallet to lightly tap on the base of the shift holder assembly as you pry up the transmission case.
    • When removing the right half of the transmission case, make sure that the shift holder assembly is not coming up with the case as it is being pried up.
    • Reinstallation tip: If any of the bearings fall out of the right transmission case when installing it onto the left transmission case, install them onto their corresponding shaft on the left transmission case instead.
  57. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lightly tap on the tine shaft while prying up on the case to make removal easier.
    • Ensure the rotary chain stays seated in the bottom half of the transmission case.
  58. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pull up to work the top case away from the bottom case.
    • Make sure no internal components come out with the top case. However, there are bearings installed in the top case that may stay with the bottom half of the case.
    • Completely remove the top half of the transmission case. You may have to "walk" the top half of the case off of the shafts it is slotted through.
    • Reinstallation tip: Scrape off old gasket before putting the transmission back together. Use a Scotch-Brite pad to remove any stubborn gasket from all mating surfaces, and do a final cleaning with isopropyl alcohol.
    • Be extra cautious to not let any old gasket fall into the transmission case oil basin, as debris could potentially harm future performance.
    • Reinstallation tip: When reapplying liquid gasket to the transmission case, run a 2-4 mm bead along all gasket mating surfaces on both the left and right transmission cases. Use HondaBond 4, ThreeBond 1216, or an equivalent liquid gasket. Reassemble both transmission halves within 10 minutes of applying the liquid gasket.
    • Reinstallation tip: If necessary, use a mallet to lightly tap the right transmission case until mostly flush with the left transmission case when putting the two halves back together.
  59. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder assembly: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder assembly: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder assembly: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly pull the shift holder assembly away from the transmission gearing to unseat the shift forks.
    • Lift the assembly out and away from the rest of the transmission to remove.
    • Some gears are supported by the shift forks, so they may shift during removal.
    • Reinstallation tip: Ensure the three shift forks line up with each of their corresponding gear shift slots.
  60. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Secure the shift holder assembly: crwdns2935265:060crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Support the shift holder assembly securely in a padded vise.
    • To avoid marring the shift holder components or housing, use a vise with plastic jaw covers or use a soft towel.
  61. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder spring: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder spring: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the shift holder spring: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 2.5 mm punch to partially remove the shift holder spring pin.
    • Leave the spring pin in the shift holder. It only needs to be pushed down enough so the spring can be removed.
  62. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to remove the spring from the shift holder housing.
    • There is a #10 ball bearing securing the P.T.O. change fork in place. It is located between the retention spring and the change fork.
    • Reinstallation Tip: Each change fork is separated by two #10 steel ball bearings. If any ball bearings fall out of the shift holder assembly, ensure there are two between the PTO change fork and the middle change fork and one between the PTO change fork and the spring in the shift shaft holder passage.
  63. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the P.T.O. change fork: crwdns2935265:063crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the P.T.O. change fork: crwdns2935265:063crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove the P.T.O. change fork: crwdns2935265:063crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the retention spring removed and the ball bearing out of the way, pull the P.T.O. change fork directly out of the shift holder assembly to remove.
  64. Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove change fork oil seals: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A P.T.O. Change Fork Replacement, Remove change fork oil seals: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pick tool to remove the oil seal from the empty P.T.O. change fork passage.
    • Repeat for each removed change fork.
    • Use a pick tool to remove the large oval o-ring from the shaft holder assembly.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Carsten Frauenheim
146.050 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.729crwdne2935297:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 1,439
