Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement
  1. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin the repair, disconnect the spark plug wire.
    • Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
  2. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Turn off the fuel valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the fuel valve switch to the off position.
  3. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove outer belt cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 14 mm socket to remove the bolt securing the outer belt cover.
  4. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the outer belt cover down and pull it off of the lip on the inner belt cover to remove it.
  5. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Loosen the transmission pulley bolt: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step may require two people.
    • Pull the tine engagement lever to put belt tension on the transmission pulley.
    • With the belt taut, use a 12 mm socket to loosen the transmission pulley bolt without fully removing it.
    • The pulley will rotate with the bolt and the bolt will not be able to be removed if belt tension is not applied.
  6. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the V-belt: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the V-belt towards the transmission pulley to release tension.
    • Slip the V-belt off of the groove in the pulley.
  7. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the V-belt down and out of the way of the two-prong belt guide.
    • Push the V-belt around and off of the motor pulley to remove.
  8. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the belt guides: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the two bolts securing the belt guides to the inner belt cover.
    • Use a 10 mm socket to remove the bolt securing the inner belt cover to the frame.
  9. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Lower the guard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Lower the guard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to loosen the two bolts securing the guard to the frame.
    • These bolts have corresponding 14 mm nuts on their opposite ends. You will need to keep the bolts steady with a wrench or socket for the nuts to become loose.
    • Remove both nuts, but do not remove the bolts yet.
  10. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the frontmost guard bolt.
  11. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the guard and lower it to the ground, pivoting it on the rear guard bolt.
  12. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the pulley bolts: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the motor and transmission pulley bolts.
    • Hold the pulleys steady to more easily remove the bolts.
  13. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the motor pulley: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the motor pulley: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor pulley.
    • Keep track of the key—which may fall out on its own—and keep it with the motor pulley.
  14. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the transmission pulley: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the transmission pulley straight off of the splined shaft to remove.
  15. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the tensioner pulley: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use snap ring pliers to remove the snap ring securing the tensioner pulley to its shaft.
  16. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tensioner pulley.
  17. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the wire clips: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to remove the three wire clips securing various cables to the back of the inner belt cover.
  18. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the two remaining inner belt cover bolts behind the transmission pulley.
  19. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the inner belt cover: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the inner belt cover clear of the motor and transmission shafts.
    • Remove the inner belt cover.
  20. Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the input shaft oil seal.: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Rear Tine Tiller FRC800K1A Input Shaft Oil Seal Replacement, Remove the input shaft oil seal.: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a pick tool between the input shaft and the oil seal.
    • Pull firmly in the direction of the shaft to loosen the oil seal.
    • You may have to remove the pick tool and reinsert it at other locations around the shaft to "walk" the oil seal off the shaft.
    • Remove the oil seal.
Refill the transmission with 5.3 quarts of SAE 10W-30 oil.
Carsten Frauenheim
150,942 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023,042crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 728
