Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement
  1. Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the tine shaft: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the tine shaft: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This procedure is on the right side of the tiller. The left side has a different seal and its procedure may differ slightly.
    • Pull the snap pin straight out of the pin securing the right tine to the tine shaft.
    • The tine shaft pin may fall out when you remove the snap pin. If the tine shaft pin did not fall out, remove it now.
  3. Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tines straight off of the tine shaft.
  4. Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the grass guard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the grass guard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the grass guard straight off of the tine shaft and remove it.
  5. Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the oil seal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the oil seal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Light Duty Tiller F220K1AT715492 Oil Seal Replacement, Remove the oil seal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an angled pick under the inner ring of the seal so that you can pry the seal out of the reduction case.
    • If you did not drain the oil already, oil may start to leak out as soon as you insert the pick. Make sure you have a container ready to contain the spillage.
    • Pry the seal out of the reduction case, taking care not to mar the aluminum reduction case.
    • It may take significant force to pry out the seal. It's rigid and fits very tightly in the reduction case.
    • Remove the oil seal.
Refill the oil after reassembly.
crwdns2935229:08crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
211,185 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 2,819
