Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Restrict fuel flow: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
    • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
  3. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the fuel tank: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
  4. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Residual fuel may leak out of this hose. Be ready to catch any spillage.
    • Disconnect the fuel line from the cutoff valve.
  5. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the brake cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
  6. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull to unlatch the cable sheath.
    • Pull the brake cable away from the motor.
  7. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the cable towards the cable anchor to give it enough slack to be removed.
    • Remove the brake cable from the motor.
  8. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Disconnect the pull start cord: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pull start cord out of the small opening on the handle post and remove it.
  9. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement, Remove the fan cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 10 mm nuts securing the fan cover.
  10. Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Fan Cover and Fuel Tank Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan cover.
    • The fuel tank is connected to the fan cover. They will both come out as one unit.
Carsten Frauenheim
146.626 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022.175crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 26
