Prerequisite only! This guide shows how to remove the engine from a Honda HRS216K6 lawn mower to perform internal repairs.
Drain the fuel from the fuel tank before you begin this procedure. Any fuel remaining in the tank will spill out. Be ready to contain any spillage.
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
Turn the fuel cutoff valve clockwise so the handle becomes vertical.
Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
Disconnect the fuel line from the cutoff valve.
Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
Pull to unlatch the cable sheath.
Pull the brake cable away from the motor.
Push the cable towards the cable anchor to give it enough slack to be removed.
Remove the brake cable from the motor.
Pull the pull start cord out of the small opening on the handle post and remove it.
Remove the three 10 mm nuts securing the fan cover.
Remove the 19 mm nut securing the flywheel and cooling fan to the motor.
Remove the washer on top of the cooling fan.
Remove the cooling fan.
Use a universal puller to loosen the flywheel from the tapered pressure fit on the end of the crankshaft.
Attach the universal puller arms underneath the denoted "puller" sections on the flywheel.
Use a wrench to torque down the puller to slowly loosen the flywheel.
The flywheel will "pop" off the crankshaft once loose.
Remove the flywheel.
Use needle nose pliers to remove the flywheel key from its slot in the crankshaft.
Loosen, but don't remove, the shiny 14 mm blade holder bolt.
Remove the two matte 14 mm bolts securing the blade to the blade holder.
Fully remove the 14 mm bolt securing the blade holder to the crankshaft.
Remove the four 12 mm bolts securing the motor to the frame.
Lift the engine off of the mower frame and remove it.
