Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement, Restrict fuel flow: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
    • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
  3. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement, Remove the blade: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen, but don't remove, the shiny 14 mm blade holder bolt.
    • Remove the two matte 14 mm bolts securing the blade to the blade holder.
  4. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blade.
    • If the blade is heavily used, it may be sharp in some areas. If this is the case, use gloves to remove it.
  5. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement, Remove the blade holder: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the 14 mm bolt securing the blade holder to the crankshaft.
  6. Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda Lawn Mower HRS216K6 PKAA Blade Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blade holder.
    • If the blade holder is difficult to remove by hand, use a pry bar for more leverage.
    • The blade holder will come out with its accompanying shaft key.
Carsten Frauenheim
146,626 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,175crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 53
