Honda EU2200IT A2 Oil Level Switch Replacement
  1. Honda EU2200IT A2 Oil Level Switch Replacement, Honda EU2200IT A2 Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, make sure the generator is switched off and the generator is cool to the touch.
  2. Honda EU2200IT A2 Oil Level Switch Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the spark plug cover.
  3. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the maintenance cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
  5. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the top of the maintenance cover out.
    • Remove the maintenance cover.
  6. Honda EU2200IT A2 Oil Level Switch Replacement, Drain the engine oil: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Drain the engine oil: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the oil filler cap.
  7. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place an oil pan below the fill port to catch the engine oil.
    • Carefully tilt the generator towards the oil pan to drain the oil.
  8. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, be sure to refill the engine oil:
    • If you recently resealed the crankcase cover with liquid sealant, wait at least 20 minutes before adding oil.
    • Use SAE 10W-30 oil, up to 0.46 US quarts.
    • Add oil until the dipstick is almost completely submerged.
  9. Honda EU2200IT A2 Oil Level Switch Replacement, Drain the carburetor fuel bowl: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a container below the drain tube to catch the excess fuel.
  10. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  11. Honda EU2200IT A2 Oil Level Switch Replacement, Back Cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips screws securing the back cover.
  12. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
  13. Honda EU2200IT A2 Oil Level Switch Replacement, Loosen the front cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Loosen the front cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Loosen the front cover: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws securing the front cover:
    • Two Phillips screws
    • Two Phillips screws (one on each side)
  14. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the top edge of the front cover away from the generator.
    • Pull the front cover away slightly away.
    • The front cover still has many wires connected to it. Be careful not to strain any wires.
  15. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the left cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the left cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the left cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower gray plates from both sides of the generator.
    • During reassembly, be sure to reinstall the gray plate with the air vent cutout onto the right (access-side) cover.
  16. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fasteners securing the left (non-access) cover:
    • Two 10 mm bolts
  17. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left (non-access) cover.
  18. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the right cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the right cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the right cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the vent and drain tubes out of their cover ports along the bottom of the right cover.
  19. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips screw securing the starter rope port.
  20. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the starter rope handle through the port's cutout.
  21. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right (access-side) cover.
  22. Honda EU2200IT A2 Oil Level Switch Replacement, Fuel Tank: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Fuel Tank: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Fuel Tank: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are replacing only the fuel tank, you can skip the next six steps.
    • Use a screwdriver to pry and loosen the diaphragm tube from the fuel pump.
    • Disconnect the diaphragm tube from the fuel pump.
  23. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of pliers to squeeze and slide the spring clip off the fuel pump port.
  24. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Residual fuel may leak out of this hose. Be ready to contain any spillage.
    • Disconnect the fuel hose from the fuel pump.
  25. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the engine stop switch connector from its socket.
  26. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips screw securing the starter rope guide.
  27. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the starter rope handle and guide through the panel cutout.
  28. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the fuel tank: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the fuel tank: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Any residual fuel in the tank will leak. Be ready to contain any spillage.
    • Use a pair of pliers to squeeze and slide the spring clip off the fuel tank port.
  29. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fuel line and filter from the fuel tank.
  30. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips screw securing the left (non-access) frame assembly.
  31. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left (non-access) frame assembly.
  32. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the fuel tank.
  33. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the muffler: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three bolts securing the muffler:
    • Two 50 mm-long bolts
    • One 75 mm-long bolt
    • During reassembly, these bolts should be tightened to 8.7 lb-ft.
  34. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the muffler.
  35. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a wire brush to clean any deposits off the spark arrester.
  36. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the muffler gasket if it shows signs of wear.
  37. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the under-cover: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to pry up the blue wire harness from the under-cover.
  38. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a mallet and punch to tap out the front collar (closest to the electrical panel) securing the motor assembly to the under-cover.
  39. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the motor rear to the under-cover.
  40. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motor assembly is heavy. Follow safe lifting practices when you lift the assembly.
    • Lift the motor assembly off the under-cover and set it aside.
  41. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the left shroud: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the left shroud.
  42. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin separating the left shroud from the engine assembly by pulling it away from the assembly.
    • The shroud sits in a groove on the engine assembly and may take some force to pull out.
  43. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull along the edge of the shroud until you separate the shroud from the engine assembly.
    • Remove the shroud.
  44. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the air filter housing: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the air filter housing: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Phillips screw securing the filter cover.
    • During reassembly, be sure to tighten the screw to at least 1.7 ft-lb to prevent it from loosening during operation.
    • Remove the filter cover.
  45. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air filters from the filter box.
    • To clean the filters:
    • Clean the filters in warm soapy water
    • Allow the filters to dry thoroughly
    • Dip the filters in clean engine oil, and squeeze out excess oil
  46. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the breather tube from the air cleaner housing.
  47. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following fasteners securing the housing:
    • Two 8 mm nuts
    • During reassembly, tighten these to 3.6 ft-lb.
    • One 8 mm bolt
  48. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air filter housing.
  49. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the air intake gasket if it shows signs of wear.
  50. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, use this photo as a reference for how to route the hoses.
  51. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the fuel and air hoses from the side of the motor assembly.
  52. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the breather tube straight out of its port.
  53. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to unclip the carburetor wires from the side of the motor assembly.
  54. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the carburetor off its two bolt rails.
  55. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the carburetor seal if it shows signs of wear.
  56. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 8 mm socket to remove the two bolts securing the carburetor insulator.
    • During reassembly, tighten these bolts to 2.2 ft-lb.
  57. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the carburetor insulator along with the two bolt rails.
  58. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the insulator gasket if it shows signs of wear.
  59. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the bolts securing the right shroud.
  60. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin separating the right shroud from the engine assembly by pulling it away from the assembly.
  61. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the shroud away along the edge. Use a flathead screwdriver to pry it out of the engine assembly groove.
  62. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right shroud from the engine assembly.
  63. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the exhaust pipe: crwdns2935265:063crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the exhaust pipe.
  64. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the exhaust pipe from the engine assembly.
  65. Honda EU2200IT A2 Oil Level Switch Replacement, Disconnect the engine oil sensor: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the cable tie securing the engine oil sensor.
  66. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the yellow engine oil sensor wire by pulling the connector apart.
  67. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the engine oil sensor ground.
  68. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the crankcase cover: crwdns2935265:068crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement, Remove the crankcase cover: crwdns2935265:068crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the eight bolts securing the crankcase cover.
    • During reassembly, hand-tighten the crankcase cover bolts in the pattern indicated in the second image.
  69. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The crankcase cover is sealed with liquid sealant and must be pried apart.
    • Be ready to contain any residual engine oil that may spill from the crankcase.
    • Insert a large flathead screwdriver or pry bar into the crankcase seam and pry to loosen the crankcase cover.
    • Do not use too much force, or you may gouge the mating surface.
    • Pry along the entire crankcase perimeter until you fully loosen the crankcase cover.
  70. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:070crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate and remove the crankcase cover.
  71. Honda EU2200IT A2 Oil Level Switch Replacement, Reseal the crankcase: crwdns2935265:071crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reseal the crankcase during reassembly:
    • Clean all adhesive and oil residue off of the cover and crankcase mating surfaces.
    • Apply a bead of liquid sealant to the crankcase.
    • Fit the crankcase cover to the crankcase.
    • Do not fill the crankcase with engine oil for at least 20 minutes after sealing the crankcase.
  72. Honda EU2200IT A2 Oil Level Switch Replacement, Remove the oil level sensor: crwdns2935265:072crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the oil level sensor.
  73. Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:073crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:073crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Oil Level Switch Replacement: crwdns2935265:073crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the sensor cable through the port and remove the sensor.
    • Be sure to check if your replacement sensor has an O-ring pre-installed on the sensor's mating surface. If it doesn't, transfer the O-ring over.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297.665 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.614crwdne2935297:0
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 6,703
