Honda EU2200IT A2 Intermediate Disassembly
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Honda EU2200IT A2 Intermediate Disassembly, Remove the under-cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to pry up the blue wire harness from the under-cover.
  2. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a mallet and punch to tap out the front collar (closest to the electrical panel) securing the motor assembly to the under-cover.
  3. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the motor rear to the under-cover.
  4. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motor assembly is heavy. Follow safe lifting practices when you lift the assembly.
    • Lift the motor assembly off the under-cover and set it aside.
  5. Honda EU2200IT A2 Intermediate Disassembly, Remove the left shroud: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the left shroud.
  6. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin separating the left shroud from the engine assembly by pulling it away from the assembly.
    • The shroud sits in a groove on the engine assembly and may take some force to pull out.
  7. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull along the edge of the shroud until you separate the shroud from the engine assembly.
    • Remove the shroud.
  8. Honda EU2200IT A2 Intermediate Disassembly, Remove the air filter housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly, Remove the air filter housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Phillips screw securing the filter cover.
    • During reassembly, be sure to tighten the screw to at least 1.7 ft-lb to prevent it from loosening during operation.
    • Remove the filter cover.
  9. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air filters from the filter box.
    • To clean the filters:
    • Clean the filters in warm soapy water
    • Allow the filters to dry thoroughly
    • Dip the filters in clean engine oil, and squeeze out excess oil
  10. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the breather tube from the air cleaner housing.
  11. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following fasteners securing the housing:
    • Two 8 mm nuts
    • During reassembly, tighten these to 3.6 ft-lb.
    • One 8 mm bolt
  12. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air filter housing.
  13. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the air intake gasket if it shows signs of wear.
  14. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, use this photo as a reference for how to route the hoses.
  15. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the fuel and air hoses from the side of the motor assembly.
  16. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the breather tube straight out of its port.
  17. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver to unclip the carburetor wires from the side of the motor assembly.
  18. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the carburetor off its two bolt rails.
  19. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the carburetor seal if it shows signs of wear.
  20. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 8 mm socket to remove the two bolts securing the carburetor insulator.
    • During reassembly, tighten these bolts to 2.2 ft-lb.
  21. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the carburetor insulator along with the two bolt rails.
  22. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, replace the insulator gasket if it shows signs of wear.
  23. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the bolts securing the right shroud.
  24. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin separating the right shroud from the engine assembly by pulling it away from the assembly.
  25. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the shroud away along the edge. Use a flathead screwdriver to pry it out of the engine assembly groove.
  26. Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda EU2200IT A2 Intermediate Disassembly: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right shroud from the engine assembly.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,635 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,614crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 40
