This guide shows how to remove and replace the air filters on the Honda EU2200IT generator.
Lift and remove the spark plug cover.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
Swing the top of the maintenance cover out.
Remove the maintenance cover.
Remove the Phillips screw securing the filter cover.
Remove the air filters from the filter box.
Clean the filters in warm soapy water.
Allow the filters to dry thoroughly.
Dip the filters in clean engine oil, and squeeze out any excess oil.
