Honda 6500 Watt Generator EG6500CL AT Stator Replacement
  1. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you work on the device, make sure to switch the engine off.
    • Switch the circuit breaker off.
  2. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Disconnect the spark plug: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the fuel valve clockwise into the cutoff position.
  4. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the generator cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws securing the generator cover.
  5. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the generator cover.
  6. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the brush assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the brush assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze and disconnect the stator connector from the wiring harness.
  7. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the brush assembly.
    • Pull the brush assembly out slightly from its recess.
  8. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two spade connectors from the brush assembly.
  9. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the brush assembly.
    • During reassembly, use the second photo as reference for how to wire the brush assembly.
  10. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Loosen the rear generator housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the four long bolts securing the generator cover to the generator assembly.
    • During reassembly, tighten these bolts to 7 ft-lb (10 N-m).
  11. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to remove the rotor bolt from the generator assembly.
    • This bolt may be difficult to loosen. If you have trouble removing the bolt, use an impact wrench or breaker bar.
    • During reassembly, tighten this bolt to 33 ft-lb (44 N-m).
  12. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rotor bolt and washer.
  13. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an 8 mm socket to remove the four nuts securing the wiring harness to the terminal.
    • Remove only the top nut from each terminal post.
    • Be careful not to lose the crush washers behind them.
    • Remove the wiring harness wires from the terminal.
  14. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, use these photos as a reference for how to re-stack the terminal posts. From the terminal base to tip:
    • Base washer
    • Crush washer
    • Stator wire connector
    • Nut
    • Wiring harness connector
    • Crush washer
    • Nut
  15. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an 8 mm socket to remove the three bolts securing the wiring terminal and harness.
    • Remove the Phillips screw securing the harness ground.
    • Loosen the wiring terminal and harness from their resting positions.
  16. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use pliers to release the cable tie securing the wiring harness to the generator assembly.
  17. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Loosen the mounting bolts: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully tilt the rear of the generator upwards to access the under-frame bolts.
    • Use a 12 mm socket to remove the two bolts underneath the frame, which secures the rear generator housing.
  18. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing these nuts give the generator assembly enough slack to remove the rear bushings.
    • Use a 14 mm socket to remove the mounting nut next to the emissions canister.
    • Use a 14 mm socket to remove the mounting nut near the oil filler hole.
  19. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to remove the two nuts securing the rear housing to the bushings.
    • During reassembly, be sure to re-attach the ground terminal to the left bushing.
  20. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear bushings: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In these photos, the generator frame is propped on some blocks for ease of access. You do not need to do this for the procedure.
    • Tilt the generator assembly by lifting the rear housing slightly.
    • Place support blocks underneath the silver generator housing to support the generator assembly.
    • The generator weight should rest on the support blocks and no longer on the rear bushings.
    • Do not support the generator by the black stator cover.
  21. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the rear generator housing up as far as you can and maneuver the left bushing out of its socket.
    • Remove the left bushing.
  22. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous step to remove the right bushing from its socket.
  23. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear generator housing: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the rear generator housing: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear generator housing from the generator assembly.
  24. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator cover: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator cover: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the stator cover so that the seam is at an accessible angle.
  25. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to pry up the tabs holding the stator cover together.
  26. Honda 6500 Watt Generator EG6500CL AT Stator Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stator cover.
  27. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Remove the stator: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the stator by pulling it straight out of the generator assembly.
  28. Honda 6500 Watt Generator EG6500CL AT Stator Replacement, Reassembly tip: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During reassembly, you don't need to install the stator in a precise rotational position. Just make sure the stator cables wires are in the top-left corner.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
302,045 crwdns2915208:0crwdne2915208:0
crwdns2935297:0689crwdne2935297:0
Staff
crwdns2931471:0118crwdne2931471:0
crwdns2935297:022,741crwdne2935297:0
How to remove the armature from the flywheel
westcoaststyle3 - crwdns2934203:0crwdne2934203:0
How to rewind the stator Generator ?
Taher Dawud - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 2,260
