This guide shows how to remove and replace the automatic voltage regulator module for the Honda 6500 Watt Generator EG6500CL AT.
Before you work on the device, make sure to switch the engine off.
Switch the circuit breaker off.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Twist the fuel valve clockwise into the cutoff position.
Remove the five Phillips screws securing the front panel:
Two 35 mm screws
Two 20 mm screws
One 15 mm screw
Carefully pull the front panel away from the generator in order to access the internal components.
Use a flathead screwdriver to unclip the green ground wire from its socket.
Use a flathead screwdriver to press and release the two plastic tabs securing the AVR module.
Carefully slide and remove the automatic voltage regulator out of its recess.
crwdns2917034:0crwdne2917034:0
How do get the avr, for eg5000ex
