Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the generator is off and cool to the touch.
    • Use a large flathead screwdriver to unlock the maintenance cover.
    • Open the maintenance cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the spark plug cover.
    • Remove the spark plug cover.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Engage the fuel cutoff: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Engage the fuel cutoff: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the fuel valve to the cutoff position.
  5. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the bushing nuts: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully tilt the generator to its side or back.
    • Use a 10 mm socket to remove the two nuts securing the front bushing mounts to the bottom of the generator.
    • Carefully tilt the generator back to an upright position.
  6. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner filter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner filter: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner filter: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the four clips securing the air cleaner cover.
    • Remove the air cleaner cover.
  7. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air cleaner filter from the housing.
  8. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the breather tube from the top corner of the air cleaner housing.
  9. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the lower tube from the bottom corner of the air cleaner housing.
  10. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three fasteners securing the air cleaner housing:
    • Two 10 mm nuts
    • During reassembly, tighten these nuts to 6.3 ft-lb (8.5 N-m).
    • One 10 mm bolt
  11. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the housing out slightly from its recess.
    • The housing still has tubes clipped to it.
  12. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to pry and unclip the tube from the air cleaner housing.
  13. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the air cleaner housing.
  14. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the front cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the front cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the front cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the four capped nuts securing the front cover.
    • Remove the front cover.
  15. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the handle: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the handle: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the four bolts securing the handle to the frame.
  16. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the handle.
  17. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 8 mm socket to disconnect the battery wires from the battery terminals.
    • Disconnect the black negative cable first to prevent the risk of shorting the battery.
    • During reassembly, connect the black negative cable first. Make sure you reconnect the wires in the correct polarity.
  18. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the battery strap from the lower plate.
  19. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  20. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the lower plate: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the lower plate: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the four capped nuts securing the lower plate.
    • Set these capped nuts apart. They look similar, but are smaller than the front cover nuts.
    • Remove the lower plate.
  21. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Unclip the fuse holder: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Unclip the fuse holder: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a flathead screwdriver into the top of the brown fuse clip in order to release the fuse holder.
    • Detach the fuse holder from the brown clip.
  22. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Disconnect the choke cable: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Disconnect the choke cable: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use pliers to lift and disconnect the choke cable from the choke stay.
    • During reassembly, be sure to test the choke to ensure that it is properly connected.
  23. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the fuel cutoff switch: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a long shaft Phillips screwdriver to remove the deeply recessed screw securing the fuel cutoff switch.
    • Be careful not to turn the fuel cutoff switch while you remove the screw.
  24. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fuel cutoff switch.
    • During reassembly, be sure to test the switch to ensure that it is properly installed.
  25. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Loosen the control panel: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the four bolts securing the control panel.
  26. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully tilt the control panel downwards.
    • The control panel will still be connected to many wires and cables. Be careful not to strain any of the connected wires.
  27. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the inverter: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the inverter: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following bolts securing the inverter:
    • One 8 mm ground bolt
    • Three 10 mm bolts (one behind the control panel)
  28. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reach behind the inverter along the edges and disconnect the six connectors from the back of the inverter.
    • All the connectors use locking tabs, so you will have to squeeze them in order to release them.
    • The third image shows the locations of all six sockets on the inverter.
    • Reassembly tip: Every socket on the inverter is different, so you can't plug something into the wrong place. Do not force the connectors into their sockets.
  29. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the inverter.
  30. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Transfer the rubber mounts: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Transfer the rubber mounts: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you are replacing the inverter and the replacement did not come with rubber mounts, follow the next two steps to transfer them over.
    • Use a screwdriver to push the metal collar out of the center of the rubber mount.
  31. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the mount and remove it from the inverter.
    • Repeat the procedure with the remaining mounts and transfer them to the replacement inverter.
  32. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the rear cover: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the rear cover: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the four capped nuts securing the rear cover.
    • Remove the rear cover.
  33. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the four bolts securing the muffler protector.
    • Remove the muffler protector.
  34. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Loosen the main cover: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Loosen the main cover: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the muffler shroud slightly away from the frame to access the top frame bolts.
    • Use a 10 mm socket to remove the two bolts securing the top edge of the cover.
  35. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three bolts securing the front edge of the cover.
  36. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the four bolts from the maintenance cover side.
    • Remove the maintenance cover.
  37. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel the maintenance cover seal from the frame.
  38. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 8 mm socket to remove the two bolts securing the non-access side of the cover.
  39. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the gas cap.
  40. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the cover up slightly to free it from the frame and slide it back by a few inches.
  41. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Disassembly tip: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point, it may be helpful to temporarily re-attach the control panel back onto the front frame with some 10 mm bolts.
  42. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Release the choke cable bushing: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Release the choke cable bushing: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Release the choke cable bushing: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up and release the choke cable's rubber bushing from the choke stay.
    • During reassembly, make sure that the choke cable's rubber bushing is properly seated on the choke stay.
  43. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Loosen the front frame: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three frame bolts securing the bottom of the front frame.
  44. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the four bolts securing the top of the front frame.
  45. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the starter motor's black barrel and white barrel connectors.
    • During reassembly, the wires should be reconnected to their respective colors.
  46. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the two-wire oil switch connector.
  47. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the four-wire regulator connector from the bottom edge of the control panel.
  48. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the two winding connectors.
    • These connectors all have brown wiring in black sleeves.
  49. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the edge of a large flathead screwdriver under the bottom edge of the front frame.
    • Pry up and outward to release the bottom edge of the front frame.
  50. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully swing the front frame to the right side of the generator.
    • While the images show the control panel unbolted from the front frame, you can keep it bolted to the frame.
    • The front frame is still connected to the generator by many wires. Be careful not to strain any wires.
  51. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the recoil starter: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three bolts securing the recoil starter.
  52. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the recoil starter and move it out of the way.
    • Be careful not to lose the metal collar in each of the recoil starter's bolt holes.
  53. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the starter pulley: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the starter pulley: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the starter pulley.
    • Remove the starter pulley.
  54. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner housing bracket: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the air cleaner housing bracket: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the air cleaner housing bracket.
    • Remove the air cleaner housing bracket.
  55. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the petcock assembly: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the petcock assembly: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
    • Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel line.
    • Pull and disconnect the carburetor fuel line from the petcock assembly.
  56. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to drain the fuel tank before you perform this step.
    • Use a large crescent wrench to loosen the petcock assembly from the fuel tank.
    • Residual fuel will leak out as you remove the petcock assembly. Be ready to catch any spillage.
    • Remove the petcock assembly.
  57. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Drain the carburetor bowl: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Drain the carburetor bowl: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Drain the carburetor bowl: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a container below the carburetor drain tube to catch the excess fuel.
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  58. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the carburetor: crwdns2935265:058crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  59. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the choke stay.
  60. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  61. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the carburetor off the mounting bolts.
    • During reassembly, use the third photo as a reference for how to route the carburetor tubes.
  62. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the throttle control connector from the top of the carburetor.
    • Unwrap the throttle control wires from the carburetor.
  63. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the carburetor.
  64. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:064crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  65. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the carburetor insulator.
  66. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:066crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  67. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the fan cover: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the fan cover: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the fan cover: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the seven bolts securing the fan cover:
    • Four bolts on top
    • One recessed bolt in the bottom left corner
    • Two bolts in the bottom right corner
    • During reassembly, be sure to reattach the ground wire.
  68. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the mounting nuts securing the front bushings.
  69. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a pry bar underneath the fan cover.
    • Pry upwards to lift the generator assembly slightly.
  70. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:070crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:070crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you lift the generator assembly with the pry bar, maneuver and remove the two generator mounts from their recess.
  71. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:071crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the long bolt from the fan cover.
  72. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:072crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:072crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the fan cover away from the generator assembly.
    • During reassembly, make sure that the cord grommet is properly slotted into the fan cover.
  73. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:073crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:073crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fan cover is a tight fit. You may need to push the gas tank upwards as you maneuver the fan cover out.
    • Remove the fan cover.
  74. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the cooling fan: crwdns2935265:074crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cooling fan.
  75. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement, Remove the rotor: crwdns2935265:075crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 19 mm socket to remove the nut securing the rotor to the generator shaft.
    • During reassembly, tighten this nut to 55 ft-lb (74 N-m).
  76. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:076crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:076crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach a flywheel puller to the rotor and use it to loosen the rotor.
    • To prevent the rotor from spinning, insert a flathead screwdriver into one of the rotor slots and brace it against the ignition coil bracket.
    • Be careful not to insert the screwdriver too deeply into the slot, or you will damage the stator.
  77. Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:077crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Rotor Replacement: crwdns2935265:077crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rotor.
    • Be careful not to lose the Woodruff key.
    • During reassembly, be sure to align the rotor to the Woodruff key.
    • After you install the replacement rotor, rotate it by hand to make sure that the rotor does not rub against the stator.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298.867 crwdns2915208:0crwdne2915208:0
crwdns2935297:0684crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.981crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,340
