Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the recoil starter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three bolts securing the recoil starter.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the recoil starter and move it out of the way.
    • Be careful not to lose the metal collar in each of the recoil starter's bolt holes.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the starter pulley: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the starter pulley: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the two bolts securing the starter pulley.
    • Remove the starter pulley.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the air cleaner housing bracket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the air cleaner housing bracket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 10 mm socket to remove the bolt securing the air cleaner housing bracket.
    • Remove the air cleaner housing bracket.
  5. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the petcock assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the petcock assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
    • Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel line.
    • Pull and disconnect the carburetor fuel line from the petcock assembly.
  6. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to drain the fuel tank before you perform this step.
    • Use a large crescent wrench to loosen the petcock assembly from the fuel tank.
    • Residual fuel will leak out as you remove the petcock assembly. Be ready to catch any spillage.
    • Remove the petcock assembly.
  7. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a container below the carburetor drain tube to catch the excess fuel.
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  8. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the carburetor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the choke stay.
  10. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  11. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the carburetor off the mounting bolts.
    • During reassembly, use the third photo as a reference for how to route the carburetor tubes.
  12. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the throttle control connector from the top of the carburetor.
    • Unwrap the throttle control wires from the carburetor.
  13. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the carburetor.
  14. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the carburetor insulator.
  16. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  17. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 10 mm socket to remove the seven bolts securing the fan cover:
    • Four bolts on top
    • One recessed bolt in the bottom left corner
    • Two bolts in the bottom right corner
    • During reassembly, be sure to reattach the ground wire.
  18. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 12 mm socket to remove the mounting nuts securing the front bushings.
  19. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a pry bar underneath the fan cover.
    • Pry upwards to lift the generator assembly slightly.
  20. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you lift the generator assembly with the pry bar, maneuver and remove the two generator mounts from their recess.
  21. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the long bolt from the fan cover.
  22. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the fan cover away from the generator assembly.
    • During reassembly, make sure that the cord grommet is properly slotted into the fan cover.
  23. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fan cover is a tight fit. You may need to push the gas tank upwards as you maneuver the fan cover out.
    • Remove the fan cover.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,095 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,793crwdne2935297:0
crwdns2942667:0crwdne2942667:0 47
