Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the generator is off and cool to the touch.
    • Use a large flathead screwdriver to unlock the maintenance cover.
    • Open the maintenance cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the spark plug cover.
    • Remove the spark plug cover.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Engage the fuel cutoff: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Engage the fuel cutoff: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the fuel valve to the cutoff position.
  5. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the air cleaner filter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the air cleaner filter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the air cleaner filter: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the four clips securing the air cleaner cover.
    • Remove the air cleaner cover.
  6. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the air cleaner filter from the housing.
  7. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the air cleaner housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the air cleaner housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the breather tube from the top corner of the air cleaner housing.
  8. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull and disconnect the lower tube from the bottom corner of the air cleaner housing.
  9. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket to remove the three fasteners securing the air cleaner housing:
    • Two 10 mm nuts
    • During reassembly, tighten these nuts to 6.3 ft-lb (8.5 N-m).
    • One 10 mm bolt
  10. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the housing out slightly from its recess.
    • The housing still has tubes clipped to it.
  11. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to pry and unclip the tube from the air cleaner housing.
  12. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the air cleaner housing.
  13. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Drain the carburetor bowl: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Drain the carburetor bowl: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Drain the carburetor bowl: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a container below the carburetor drain tube to catch the excess fuel.
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  14. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement, Remove the carburetor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the choke stay off the carburetor mounting bolts and move it out of the way.
    • The choke stay will still be attached to the choke cable.
  16. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  17. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the carburetor off the mounting bolts.
    • The carburetor is still attached to the generator with wires and hoses.
    • During reassembly, use the third photo as a reference for how to route the carburetor tubes.
  18. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the throttle control connector from the top of the carburetor.
    • Unwrap the throttle control wires from the carburetor.
  19. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel hose.
    • Pull and disconnect the fuel hose from the carburetor.
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
  20. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the carburetor.
  21. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your replacement carburetor did not come with hose clips, transfer the existing clips onto the new carburetor.
  22. Honda 3000 Watt Inverter Generator EU3000IS1AWK Carburetor Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298 176 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 823crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 6,527
