This guide demonstrates how to remove or replace the air cleaner and canister assembly on your Honda EB3000CK2A 3000 Watt Generator.
In this guide, the generator is shown with the recoil starter already removed. It is not necessary to remove the recoil starter to remove or replace the air cleaner and canister assembly.
Drain all fuel from the device before beginning this guide.
There are a large number of fasteners on the generator that must be removed for this repair. In order to keep them all organized and accessible, replace them in/on the same bolt hole or stud they were removed from as you work through the guide.
Use a 10 mm socket to remove the two 20 mm-long bolts securing the sides of the control box case.
Remove the control box from the generator frame and tilt it downwards.
Use a 10 mm socket to remove the five bolts securing the muffler protector and the fuel tank to the frame:
Two 25 mm-long bolts
Three 15 mm-long bolts
Use a pair of pliers to remove the lock pin and clutch joint securing the fuel tank to the frame.
Use a 10 mm socket to remove the two 20 mm-long bolts securing the fuel tank bar to the rest of the frame.
Remove the fuel tank bar.
Identify these two tubes and their tube clamps:
The tube connected to the bottom of the fuel tank
The tube connected to the petcock assembly
Use a pair of pliers to squeeze and shift the first tube clamp down the fuel tank tube.
Disconnect the tube from the fuel tank.
Use a pair of pliers to squeeze and shift the second tube clamp left and away from the petcock assembly.
Disconnect the tube from the petcock assembly.
Gently lift one side of the tank and slip it out of the generator frame.
Remove the fuel tank.
Remove the muffler protector.
Lift the choke rod off of the air cleaner housing.
Continue lifting the choke rod until it's free from the generator.
Remove the choke rod.
Unclip the two clips on top of the air cleaner housing.
Tilt the air cleaner cover down slightly.
Use a flathead screwdriver or a pick to remove the air cleaner element from the air cleaner housing.
Use a 10 mm socket to remove the two nuts from the inside of the air cleaner housing.
Use a 10 mm socket to remove the 20 mm-long bolt from the inside of the air cleaner housing.
Pull up and disconnect the breather tube from the top of the air cleaner housing.
Lift up the canister assembly from its mounting rails to release it from the generator frame.
Remove the air cleaner and canister assembly.
