Homedics UHE-CMP15 Charging Cable Cleaning
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Homedics UHE-CMP15 Charging Cable Cleaning: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
crwdns2935283:010/30/23crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Konn Fall 2023 crwdns2935289:0UMass Dartmouth, Team 3-6, Konn Fall 2023crwdne2935289:0
UMASSD-KONN-F23S3G6
crwdns2942667:0crwdne2942667:0 229
