flip your speaker onto its back.
using your scissors, carefully cut through the fabric just enough so you can remove it from the speaker's body.
using your spludger, pry out the 8 plastic plugs that are hiding the screws.
using your screwdriver, remove the 8 screws that are holding the speaker's body together.
using your spludger, carefully pry into the base.
using your screwdriver, remove the 6 screws that are holding the speaker in place.
using the spludger, carefully pry under the speaker to get it out.
carefully using 2 fingers, remove both of the connectors that connect to the speaker from the motherboard.
