Holmes box fan motor replacement
  1. Holmes box fan motor replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Holmes box fan motor replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Holmes box fan motor replacement, Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
    My plug won’t unplug from the back of the fan what do I do? How should I try to get it out. The plug is really stuck in their.
    Marisol Walls - crwdns2934203:0crwdne2934203:0
  2. Holmes box fan motor replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Holmes box fan motor replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Holmes box fan motor replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Holmes box fan motor replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Holmes box fan motor replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Holmes box fan motor replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now you can insert your new motor and you are done!
Max Cossalter
crwdns2935283:009/29/15crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-4, Green Fall 2015 crwdns2935289:0Cal Poly, Team 15-4, Green Fall 2015crwdne2935289:0
CPSU-GREEN-F15S15G4
crwdns2947412:05crwdne2947412:0
Where might one find a replacement motor for a older box fan
Chris Cook - crwdns2934203:0crwdne2934203:0
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - crwdns2934203:0crwdne2934203:0
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - crwdns2934203:0crwdne2934203:0
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - crwdns2934203:0crwdne2934203:0
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 13,161
